what can i use to stick the new apron to the bumper or will just the two screws each side be fine?
Or Sikkaflex, or the white PU that Machine Mart do. Screws alone won't hold it for ever.
Neither will just adhesive, i think, well it didnt hold one of my skirts one. i got a funny rattling,then i got my arse into gear screwing them on aswell
If you're relying just on the glue, you really have to scratch up and clean both the surfaces (acetone or spirit wipe). It's certainly safer to pop the odd screw or rivet in there. (Stainless by choice.)
2 or 3 will do it. Don't forget the washers each side to spread the load!
I've never fitted arches, but it makes sense to do it the same way. One trick, if you're painting stuff after you've bonded it on, is to give the edge whre the tiger seal is a wipe with spirit wipe (not white spirit) on a clean cloth: it smooths the edges really nicely. Then you can paint over the tiger seal and it won't show at all.
Where do you rivet them and not expose the heads?? i dont like the thought of seeing kits riveted on
i have a set of arches, and there no rivit holes, just lots of glue and cracked screw holes
yeah looks like it, there a few screw holes going into the lip of the arch.
What arches you have?
i have a pic of them taped on,but carnt find it.
i have the hormann narrow arch kit,same as alex(ghostwkd) had on his cinq
