Cee-Jay New member Written a guide Joined Jun 19, 2008 Messages 85 Points 25 Location SE London Jul 18, 2008 #1 Does anyone know how to remove the aerial from a mk2? The base part of it... Do you just pull it off? I dont wanna break it.. Last edited: Jul 18, 2008
1383matt sdb-punto's evil twin Written a guide Joined Mar 14, 2008 Messages 859 Points 196 Location norwich Jul 18, 2008 #2 i think you have to remove the courtesy light and there is a bolt underneath undo this and it should be it!
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Jul 18, 2008 #3 1383matt said: i think you have to remove the courtesy light and there is a bolt underneath undo this and it should be it! Click to expand... I'd suggest u remove the ariel first... Then Pop the interior light out (Watch out u dont break the clips on the side...) Then there is a 12mm or 14mm Nut on the inside And simply just undo that The cable with drop off - and keep the washer if it has one And HEY PRESTO done While its off - i advise u clean around it -u'd be surprised what sits under there.... Ziggy
