Can't you get the battery charged? Maybe some neighbour has a charger?
gr J
good idea.
gr J
good idea.
All suggested 18 months ago..
But the present failure after 10 minutes of engine running.. doesnt fit the conventional
'Low power' scenario
Phase 1.. get the battery checked
This doesn’t sit well with me.
Right now, everything is pointing towards the battery struggling.
The reason for posting is for my own records. Also, as mentioned I have said that when/if the light occurs again, then it will be taken to be looked into. Right now, everything is pointing towards the battery struggling. I will now no longer continue to post until the next event, when the car will be looked into.
Plenty doable for a diy'er, garages all seem to say they need to replace the column at great expense but individual parts are available, just not from fiat. But i see no reason why supplied with the parts a mechanic couldn't swap it in an hour.
and the total bill should be in the order of £500-£600, but they'll have a known good, warranted column and hopefully will be able to run the car for a few more years without this issue recurring (which it certainly will if they just do nothing).
If they take it to a franchised dealer, the repair will likely cost more than the car is worth.
To be honest we’re talking about a mk2 Punto which unless it’s the 1.3 multijet almost all of them are now less than £500-600 to buy on eBay, Facebook market place and alike. It’s actually cheaper now to buy another Punto than it is to bother repairing power steering problems unless you are going to repair it yourself as discussed
Er, no, it's a 9yr old Panda with 65k on the clock; probably worth somewhere in the region of £1500 in good order. Decent £30 RFL cars are holding their value well just now.
Obviously there is a fault and it keeps coming back. Posting each day to say “made it” doesn’t mean the fault is gone or the car is safe
There are plenty of posts around the forum if you look where failed power steering has resulted in accidents, one example I found here https://www.fiatforum.com/newbie-ce...-crashed-nearly-died.html?342835=#post3409406
I know there is another where someone’s father borrowed there car and the steering failed mid corner and caused an accident.
The main problem isn’t driving in a straight line it’s when you go into a hard or sharp corner and the steering quits in that moment, the power assist fails and you find yourself having to deal with the full (extremely heavy) weight of the steering mid corner.
You need to get this problem checked out properly and fixed
I know you say that the steering still works even with the light on, but it’s a very small step from the light being on to the car cutting power to the steering.
Basically as it currently stands you’re knowingly driving a dangerous car and knowingly putting yourself and other people at risk. If you did have an accident your insurance company and the police would be both pretty annoyed with you, and you could find yourself uninsured and prosecuted
electronic steering failure may be a shock to the driver but it is not dangerous, if you are cornering when it fails the wheels will remain in the correct position for instance. Fly by wire systems on the other hand........
