My 1.6 Active is now 4 years old and has now got a problem with the rear wiper. When the front wipers are turned on the rear one comes on .Has anyone else had this problem,and if so how did you fix it.
In reverse mine does this, but when i had an earth problem (on the headlamp!) the rear one activated on its own, or came on with the fronts (when going forwards)
Its the same fault as Big Black's. If I witch the front ones on the rear come on as well !The reverse operation is ok. How did you sort the headlight earth problem big black ?
