N needspeed New member Joined Oct 28, 2007 Messages 40 Points 18 Location plymouth Jul 13, 2008 #1 hi, got mot tomorrow and was wondering if the rear wiper was part of it because mine don't work. will this mean it will fail.cheers
craigb244 Patron member Parked in the garage Written a guide Joined Nov 1, 2007 Messages 5,853 Points 858 Location Bridgnorth Jul 13, 2008 #2 as far as i know, the rear wiper is optional. but im unsure that if its fitted it has to work? If you cant fix it I would just remove the arm all together.
levemircento Get a wriggle on! Parked in the garage Written 10+ guides Joined Dec 10, 2006 Messages 2,372 Points 743 Location wilmslow, cheshire Jul 14, 2008 #3 not a testable item, along with the spare wheel
gazzaman2k Patron member Parked in the garage Joined Mar 7, 2005 Messages 2,859 Points 508 Location Leicester Jul 14, 2008 #4 no rear wiper is not on mot
OP OP N needspeed New member Joined Oct 28, 2007 Messages 40 Points 18 Location plymouth Jul 14, 2008 #5 cheers guys
L larsson1971 New member Joined Jun 22, 2008 Messages 23 Points 6 Location scotland Jul 15, 2008 #6 you should be ok , not a tested item
Lolita is back Joined Dec 6, 2006 Messages 8,015 Points 1,042 Location FF's imagination Jul 16, 2008 #7 mine seized a while back... easy enough to fix, just removed the motor, drilled a tiny hole in it and squirted some WD40 in it. the "park"sensor has gone from it now but that doesn't matter.
