General rear wiper not working
DanR114GTa
Nottingham
ive replaced the wiper motor and it still doesnt work makes a clicking noise when you twist the switch to turn it on
ive checked the fuses and there all ok
im not very good with electrics so im stuck on whats wrong with it
any other ideas?
thanks in advance
open the boot, you will see 5 metal contact plates on the edge of the boot.
If you unscrew the two screws either side, check that the plastic wiring holder hasnt melted away.
This happened to my original punto and caused the rear wiper to intermittently work, and the rear heated window didnt work at all.
crimped some new terminals on the end of the wire and slotted it back on and both worked fine after that.
fiat_freak
Cornwall
Sometimes the actual wiper arm seizes up through lack of use. Happened to mine. Took it all to bits, cleaned and greased it all until it all moved freely and it's been fine ever since. Worth a try?
OP
OP
DanR114GTa
DanR114GTa
Nottingham
i got a differnt motor and pluged that in on its own and it still didnt work
they they have relays or something?
the wiper arm on my punto was snapped thanks to a chav
The Sultan
Bravo 1.8 HLX FTW
lake windermere east edge
you did have the boot shut when you tried the second wiper motor
and in the first instance did you replace the motor gearbox arm and everything sticking out the boot or just simply switch out the motor
as people have said the arms coming up throu the plastic guide containing the screen wash have been know to corrode and seize the shaft within the plastic tube
Davren
Moderator
Staff member
London, UK.
You say you pluged the new motor in "on it's own" did you fit it with it's mounting screws or just let it hang on it's wires? It may need to be fitted to to the boot lid to get an earth connection.
If your car has the sprung connection plates as mentioned above, don't forget it will only work with the boot shut. (you did say "not very good with electrics").:)
Dave.
OP
OP
DanR114GTa
DanR114GTa
Nottingham
ah i get it now thanks alot for the help ill try that tomorrow as its raining now
yes im rubbish with electrics lol its a real headache for me
The Sultan
Bravo 1.8 HLX FTW
it does not need the boot lid for earth it's wired but still boot needs to be closed for a closer look at whats going on pull down the back seats
hjalte81
Did you ever find a solution?
I think I have the same problem as you DanR1114GTa
