J Jaycartwright New member Joined Nov 1, 2016 Messages 10 Points 5 Nov 3, 2016 #1 I noticed today that both the rear windows don't work the handle turns but the window don't move? Any one have any ideas and is this a common problem?
D DGPunto Patron member Joined Jan 2, 2013 Messages 740 Points 198 Nov 3, 2016 #2 There's a guide here: https://www.fiatforum.com/grande-pu...o-replacement-external-rear-door-handles.html that explains how to get inside the rear doors (though that one is ultimately to replace the outer door handles). Might give you a start to have a look and see what's not moving
K Kornela New member Joined Jun 25, 2016 Messages 19 Points 5 Nov 9, 2016 #3 Had the same issue in mine it the wire in the regulator has snapped replaced the window regulator and it's fine now preatty easy job to do.
Michael Dranfield Member Parked in the garage Joined Apr 16, 2016 Messages 543 Points 140 Location Buxton Derbyshire Nov 9, 2016 #4 This is a common problem caused by bad design,water running directly onto the steel window winder cable causing it to rust and snap,replacement regulator assembly can be bought in e bay,put plenty of grease on the new regulator cable before fitting.
