Technical Rear window washer.
It's not passing fluid so can't clean back window. But my main concern was the floor behind the driver's seat is soaking wet, my partner thought that if my back washer wasn't working then it could be leaking causing the soaked carpet, but if the washer runs along passenger side then it's obviously not that!? Thanks for the reply!
Usually the rear washer issue is between the hatch and car body. There's a concertina rubber hose at the top of the hatch. The wiring and the hose usually fail inside that
Don't know whether that means the water would then run through the boot and into the rear floor though
Have you checked the door seals are OK?
I just have a three door Punto so don't think it's the door seals as the front foot Wells are dry! Thanks for replying.
To make it easier ... That's the wiring path, but I'm pretty sure the pipe runs the same way .
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
