I put the standard wheels and trims on PTP today, and while I think they look great, the rear wheels are making a metal on metal scraping/clunking sound when turned. (The fronts have small spacer plates on by the looks of things) I tried:
1-Two standard wheels on had the same effect
2-checking behind the wheel to see if anything is rubbing, it isnt
3-turning the hub by itself, no sound
4-checked for play for wheel bearing issues, but no play
5-the alloy wheel back on was fine
So I am thinking that the wheel bolts are longer to compensate for the alloys (I have pmed Kev to check this) but I am wondering if anyone else has any ideas of what the problem could be?
And if it does turn out to be the case, does anyone know what size the standard bolts are?
