Technical Rear hub mount bolt pattern
Hey guys
Does anyone happen to have a technical drawing or measurements of the bolt pattern of where the rear hub bolts on to the beam. I'm planning on fitting the rear hubs from an MG ZR and want to make an adapter plate, I have the ZR bolt pattern but don't really want to go taking hubs off the Sei just to measure if I don't have to.
Tia
The rear hubs bolt on with a single nut through the centre? No bolt pattern to it. The spindles are welded into the rear arm. Easy enough to chop off :)
Do you mean the brake mount bolt pattern?
