Hi all, apologies if this has been dealt with elsewhere but I couldn’t see it…
‘09 GP - The pins holding the OSR brake shoe in place snapped and dropped out while driving recently (luckily I was close to home). I had planned to just replace the pins/clips but of course it has snowballed into a bigger job. On stripping the brakes down, the shoes were actually pretty heavily worn so decided replace them at the same time but it seems the wheel cylinders are shot too with a slight leak under the seals on both sides of the car too.
I have the new shoes/fixing kit ready and I’ve cleaned off the rust and refinished the drums ready to go too but I can’t for the life of me get the cylinders off the backplate to replace them.
Is there an easy way to remove the whole hub and backplate assembly so I can get easier access to the back side and the cylinder fixings? Might end up replacing the whole backplate instead if I’m still struggling…
Thanks in advance
Thanks in advance
