One thing after another?
The problem i had was the n/s/r door handle not opening, I solved that by shortening the cable and that solved the issue,
But I’ve noticed now everything is bolted and secure on the door, when you pull the handle it comes away from the door a few mm like it’s going to just pull off, You can see why because there’s only 2 bolts holding it, (1 centre and one on the right) there seems to be to much flex within the handle, (another GP issue I’ve read) has anybody got a fix for this? Apart from maybe using some silicone or glue maybe, Only downside with this is if I have to take the handle off in the future
The o/s/r handle is fine and doesn’t do this
