S StuCroll New member Joined Feb 22, 2014 Messages 7 Points 2 Mar 4, 2014 #1 Hey guys, Quick question, if I have a break in one of the lines or wires of the rear demister would that stop it from working? Cheers
oldhammer Busy rebuilding pand'a Parked in the garage Joined Oct 10, 2012 Messages 5,108 Points 1,075 Location manchester'ish' Mar 4, 2014 #2 if I have a break in one of the lines or wires of the rear demister would that stop it from working? A: Yes. if Fuses/switch are good, Then it couid be a broken /chaffed wire too, check inside the rubber boot..between tailgate & car,
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,278 Points 3,365 Location Norfolk UK Mar 4, 2014 #3 if its the lines that make up the heater then only the line that is broken should not work, if its one of the larger tracks that feed several lines then non of the lines distal to the break will work. if its the whole heating element thats not working then its as oldhammer says likely fuse, switch or wiring to the rear screen
jon1612 Patron member Joined Nov 2, 2013 Messages 816 Points 167 Location yorkshire of course Mar 4, 2014 #4 StuCroll said: Hey guys, Quick question, if I have a break in one of the lines or wires of the rear demister would that stop it from working? Cheers Click to expand... there is some paint you can buy to repair broken tracks, its very fiddly but did manage to repair most of mine years ago, usualy makes the track a bit wider where you have repaired it but seems to work ok, hardest part is finding all the breaks http://www.halfords.com/webapp/wcs/..._productId_203667_langId_-1_categoryId_255229
