General Rear brakes
General Rear brakes
OP
OP
S
sammy657
Ah thats grand then lol. Just noticed that my brake warning light flashes on and off intermittenly it never used too :(
OP
OP
S
sammy657
Worried to top it up tho as i dont know what fluid was put in it before and i dont want to mix it up
Glasgow
hmmm it doesn't matter, as DOT4 brake fluid is the most common fluid unlike engine oil.
At least open the cap and see if there is any fluid in it. They should really check that when they changed the pads!
Ming
OP
OP
S
sammy657
Have noticed it was low a few days ago. Should i top up before they do it friday? How much is a small bottle of dot 4? Is it easy to put in?
OP
OP
S
sammy657
Ah i will do that so. Will i notice any difference for example less pedal travel? Will any brand of dot 4 work even if its halfords and is it ok to mix different brands?
Liverpool
Any DOT 4 will mix fine. You might even stop by the place that you're booked into and they should do it for good customer relations, etc.
Glasgow
Hold on, are you from the UK ???? How come u said the service cost 180 euro ?????
OR u getting the service done outside UK???
Ming
OP
OP
S
sammy657
From the republic of ireland mate. Just noticed after topping up i now have a leak coming from my rear left must be the brake system as it looks like its dripping from the inside of the tyre and down the rim. Is this a brake leak ?:( Hope its not an expensive fix only just started happening. Oh why me lol
Brooky
Well-known member
Lancaster
get it looked at asap.
not only will you loose brakes, you'll also loose paint work, and i dont know how it reacts with tyres
