Technical Re 1.9 2008 stuttering when accelerating hot or cold
East anglia
Hi my car stuttering quite intensely but stopped now when engine running normally hot or cold it purrs smooth I have a problem with the turbo pressure Converter highinput checked wires does anyone have the ecu pins to check wires to it please thanks and ohm ranges thanks in advance.
But I got egr flow insufficient too I cleaned it checked for leaks on the inner valve no leaks but comes up every now and then any clues neither fault is permanent stored I can erase it and then at some point randomly mil light comes on and limp mode I turn off and on again and it is fine till the next time it usually does it when boosting?
Model
Fiat punto 1.9 2008 114000miles.
Year
2008
Mileage
114000
