Rc
Rc
Grimsby
Does anyone on the forum do any sort of RC?
Personally I fly but any sort of 'RC' input would be good.
Would like to possibly meet up/chat with like minded members.
For those in the know I have a 6 channel Blade 400 (Helicopter) and a 3d Cap 232 (both electric) and fly pretty much wherever there is space, although the plane is currently on eBay as I don't use it much.
Ffoxy is quite knowledgeable on RC heli's, I'm sure she'll be along soon to add to the thread. (y)
I used to have a Savage monster truck which I destoyed after have it tuned.
Brought a couple of small heli's, twin rotor jobbies and liked em. Not sure I have the skill or the patience for a single rotor.
Think I'll stick with the Monster Trucks.
i have - HAD 3 nitro RC models
1/10 scale U-GO FS racing truck 4x4 - maxed out at just under 80mph:D
- ripped wheel off with rear left drive shaft when it got stuck in a gap between some rocks:( - i wasn't driving it then:cry:
1/8 HPI HOT BODIES Lightning Stadium Sport 4x4
- crashed into a rock on a beach - couldn't locate a replacement part, left it too long to repair, engine seized - recently took gears out to replace melted unit in my latest rc Buggy:D
1/8 Ansmann Virus 4x4 Buggy
- Gearbox melted on high speed tuning in a small garden:p
so i'm not using the HPI HOT BODIES Lightning sport gearbox with 1/2 mm clearance around the gears(y) - took a LONG time to fit the gears in without them hitting chassis :mad:
I use the spektrum DX3.0 radio system 2.4 GHz with high torque servos 14kg/0.07 sec - Car only wieghs 7-8 kgs:D
You're not alone :p been though 4 sets of blades without a fully successful indoor flight :doh: small eletric Robbins something 24
If anyone is interested in starting to fly an RC helicopter I've found this on ebay that has an on-board camera with very slight damage but doesn't affect flying (apparently)
If I had any money I would be bidding on this but because I don't I thought id share it with the RC enthusiasts on here
http://cgi.ebay.co.uk/330518267489
Get it bought, I'll do this from the top:
Twin rotor heli's are called co-axial or contra rotating, they are superb starter heli's as they have two sets of rotor blades, one spins clockwise the other anti-clockwise, thus eliminating the need for a tail rotor in order to control yaw or left and right steering, to turn left the anti clockwise rotors simply spin slower so that the forces from the clockwise rotors force the body to the left and vice versa.
They are whats called fixed pitch (FP) which means the rotor blades never move apart from spinning round and are incredibly stable and come in anything from 2 - 4 channel, 2ch is simple and the most basic but also the most boring, Channel 1 (CH1) would be altitude control, as the blades are set at a fixed pitch the simplicity is the more throttle you give it, the higher it goes.
CH2 would be rudder or yaw control.
3 channel heli's are the same as above but CH3 is usually forward and rearward movement/cyclic pitch enabling you to fly circuits.
4 channel adds roll (cyclic pitch)/sideways movement allowing you to strafe from side to side.
Stay away from anything claiming to be 3.5 channel or similar, this is just cheap sh*t and isn't worth the money they claim to cost, there is no such thing as .5 or half a channel its always whole numbers like 2, 3 or 4, go for E-Flite for co-ax heli's and you won't go wrong, they're cost effective, come on 2.4ghz complete with batteries and a charger and they have an excellent re-sale value.
With all of the heli's above if you panic you can let go of everything except for the throttle and the heli will come to a standstill in the air and just sit in one place, let go of the throttle and it hits the deck.
The Blade SR120 mentioned above is a 4 channel FP but it has a single rotor set and a functioning tail rotor and is the best step into the world of single rotor heli's, although I can fly bigger I would love one for use in the house and there are same brand but cheaper alternatives like the Mcx (contra) and Msr, now in this case as the rotors spin this causes the body to spin in the opposite direction which is why they have a tail rotor which pushes against the natural spin causing the body to remain straight.
You can also get what is called a 'notar' this is only found on turbine and real heli's - also turbine - they have a single rotor set but no tail rotor, they have a sort of 'cap' on the tail with a slit in it, this allows air from the turbine to escape through the slit under pressure causing the same effect as a tail rotor and it rotates to allow for left and right propulsion.
Single rotor heli's act like an astronaut in space, which is once they move unless there is another input or counteracting force then the heli will theoretically keep travelling in that direction for eternity, obviously batteries, fuel, wind, buildings etc etc come into play but not for this explanation, so basically if you panic and let go of everything your heli will continue to fly itself until you take control or it crashes which is usually the case.
Now I fly 6CH collective pitch (CP) helicopters which means that whilst spinning round I can also rotate the blades by entering 'idle up' mode creating positive and negative pitch which changes the direction that the wind is pushed by the rotors depending on where my throttle stick is positioned (when in idle up your throttle becomes pitch control whilst the revs you controlled before remain fixed at a set rate) meaning that when I'm showing off I can fly upside down (Idle up mode contains throttle and pitch curves and is a long ass process to explain, I will explain it to anyone that wants to know about it though) my helicopter is a Blade 400 - there is a pic in the guide - and is an intermediate heli although some pilots will tell you its a good beginner heli.
6ch gets complicated so I have sourced a guide to explain it a little: http://en.wikipedia.org/wiki/Radio-controlled_helicopter.
Click this link for a demo of what you can do: This kid is 7 and has been flying since he could walk, I'm no where near as good as this kid but I can do some of it, he is also using a Nitro (NitroMethane) which can be flown 6 Channel if you set up Throttle and Pitch curves but are usually classed as 7 Channel as they use something called a governor.
There are petrol models available which are known as 'Gassers' but they operate in the same way as nitro.
The inner pic of the transmitter (TX) shows you how quick you have to be with these things but also shows you how they operate with throttle/rotor pitch and rudder on the left stick and cyclic or forward, backward, roll left and right on the right stick.
As a general guide to get this good takes YEARS of daily practice, if you are thinking of getting into this hobby you need to be aware of some stone cast rules:
1. It is a VERY expensive hobby
2. When you crash and you WILL crash your looking at roughly a £30 repair bill for a light ding and the first crash makes or breaks it for you as a hobby with 90% being the latter.
3. It takes WEEKS if not MONTHS just to learn how to hover tail in and once you can tail hover you then have to learn all orientations meaning side on, nose on etc again this takes AGES but will eventually just click.
4. Buy a simulator, a decent one (Phoenix) will set you back around £80 but it will save you thousands in the long run.
5. If possible find a local club, get loads of advice and if you can afford it take flying lessons.
6. Always buy reputable GHZ like Futaba or Spektrum, MHZ glitches and causes no end of trouble.
7. Dont forget your insurance, yes thats right you have to have it, imagine you buying a £300 heli kit and spooling up in your driveway cause your itching to get it flying and then you crash into your neighbours Porsche facing massive repair bills to the car and then to your heli, most clubs are run by the BMFA (British Model Flying Assoc.) or are affiliated and they require their insurance as standard but the cost of £29 yearly (Jan 1st - Dec 31st) covers you wherever you fly in the UK, whenever you fly upto the cost of £10m, yes ten million pounds, now hitting that Porsche doesn't seem so bad does it! However you must check with your local council as a lot of councils prohibit the use of RC in their local parks etc.
8. Have a friend with you as a spotter, you can't see whats going on around you if your flying.
9. Choose which route you wish to go, most start electric then progress into nitro mainly because its the 'norm' but as you grow with your heli so does your spares/toolbox (flightbox) making nitro not so expensive, take into account your own individual circumstances, within reason you can fly electric pretty much anywhere, nitro has to be flown at specific sites/fields costing £50+ a year because of noise and pollution and you need a bunch of extra kit like starters, glow plugs, 12v battery, fuel, massive car to transport the heli in etc etc.
10. Now you have learned your lesson with the Porsche this is the most important rule of all, NEVER EVER show off to the point where you can endanger any person, apart from being prosecuted regardless of insurance, rotor blades have a tip speed of about 200mph which means they WILL cut through whatever they hit, I have seen a video on Youtube (and its still on there) of a young lad that thought he was clever until the rotor cut through his calf.
Dogs in particular have a tendency to chase Heli's, make sure you or your spotter warn dog walkers if you are coming in to land, taking off not really a problem as you can stop but landing may be due to damage, loss of fuel or depleted battery etc, I have heard many stories of walkers not listening to pilots of bigger heli's and so dog and machine met and then walker takes dog home in a bin liner.
I fly at a local field and only take off/land when safe to do so and most dog walkers will go about their day after the dog has said hello but there is always one that think they know better.
Edit: I also have a 4ch plane called a Cap232 with a 3ft wing span, this is a 3d plane meaning it will do everything that the heli in the vid will do within reason, Youtube it and you will find someone showing its capabilities, mine is up for grabs complete minus Tx so if you wanna bargain gimme a shout.
Ive got the helicopter i linked too on watch so hopefully if it dont go too high im gonna bid on it! I wanted an rc copter for christmas but my gf wouldnt buy me one lol so il get it myself
Great post Sqwidge!
Just to expand a little further. I had a co-axle heli first (a cheap 3 channel IR model). I'd thoroughly recommend that as a starter if you are unsure how "into" flying you will be. Also these are small enough to fly indoors and if crashed, are unlikely to damage anything. You can learn a lot from these - especially how sensitive the controls are!
The Blade 120 SR is a bit of a step up and it is possible to jump straight to it but being single rotor and 4 channel means it is a bit harder and being bigger and heavier it could do damage to stuff if you crash. The MSR is ideal if you don't have big space/only fly indoors as it is just a scaled down 120 SR. In fact the MSR came first and the 120 is a scaled up version...
seriously Andy get one it'll bring out the boy in you, I'm sure Colin would agree, and is very addictive, its also very calming, once your heart has stopped racing anyway so is good for time outs.
Check out RCHeliaddict.co.uk and RCHelifreak, i'm a member of both although spend more time on addicts as freak is a USA thing, there is always cheapish heli's for sale on them both and are very good forums try the BMFA Classifieds as there is always plenty on there for sale both heli and plane but be warned as once the bug bites you want more and more.
Young Codger went from racing a 1/10th electric Tamiya TL-01Porche GT3 via various Xrays, Yokomos, Associated, Scythes and back to Xray. Ended up racing at Euro championships in UK team. Great fun (even for me as paymaster/ sponsor and chauffeur). Got a bit expensive though as things got very serious. racing against pro guys and spending £100 a meeting just on tyres, and no limit on testing (like they have now in F1 !!).
On the other hand it was a tremendous discipline for a young lad to learn, and a great spirit of rivalry with camaraderie.
. Got a bit expensive though as things got very serious. racing against pro guys and spending £100 a meeting just on tyres, .
I've never bought another set of tyres in my 4 years of rc:D - mind you i do go though a car a year:doh:
with the exception of the buggie i bought as a kit - build it your self. I've modded the parts to they'll fit from my other Destroyed models:D
Id love to have a DIY rc car, how much would a kit set me back do you think? Im not wanting anything too fancy just something to keep me entertained for a while :D
starting price is around £110 goes up into silly money
my ansman virus buggie kit 1/8 scale cost £210 but comes with everything you need expect nitro fuel and batteries for remote(y)
my kit version came the store just down the road, round the corner down that road.......
but there website is http://www.storacingproducts.com (North East London)
The HPI website is....... i'll find it 4 you, they list other websites and store in any area for you to look at also
Are you racing indoors on carpet, or outdoors? 4 years????!!!!!
I used to race a TA03F in true tamiya. Seems limits have come in now on foam tyres which is a shame. I used to love the smell of tyre compound :D
Still have the Tam and also the HPI RS4 that I really shouldn't have upgraded to. Moving from true tam where I was a typical B/C final out of 6/7 finals I moved into pro modified. Where I often finished multiple laps down :(
Outdoor off road racing(y) Fairlop Rc Club, beach, open feilds, iced up paths, dirt paths, car parks, gardens, rocks :doh: - won't be doing that again
and yeah, 3 cars in 4 years. well
1/10 truck 1st - demolished, needs almost new everything
1/8 truck 2nd - needs light repairs & gearbox & engine rebuild
18 buggie 3rd&4th - still going
