I have this issue on my 100HP but I think it could be on other Panda models too.
There is a distinct knocking/rattling noise from the steering column when I drive slowly over small undulations and especially on cobblestone roads. This happens without the steering wheel being turned. Once over 20 mph or so the noise no longer surfaces, probably because the frequency of the bumps is lower.
It's not a low clunk as it would be from a worn suspension bush - more like the sound of shaking a pair of dice inside a wooden box.
Thing's I've replaced with no improvement to the issue: anti-roll bar drop links, anti-roll bar bushes, lower wishbones, tie rod ends, steering intermediate shaft. The front shocks and top mounts haven't been changed, but the sound really seems to be coming from inside the car, from the steering column unit behind the steering wheel.
It's also not from the instrument cluster or the parts behind it, as I took those out and the sound was still there.
Anyone has the same issue or an idea of what it could be? The steering itself works perfectly.
