Technical  radio
Technical  radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
shotgun
Established member
the radio on my qubo keeps jumping station and volume goes up and down on its own would you say the head unit is faulty
that's gr8 no buttons work also on the radio after it been on for a bit and it jumps from am to fm to lw
That kind of random jumping about sounds like it's a loose connection 'somewhere' though inside or out.... - since the outside connectors are power in, steering wheel connectors and speakers I'm thinking internal although since your (possible) steering wheel buttons change channels, if one of those has a loose wire or the molex is not secure that could be a cause? Might be worth a check on the back of the steering wheel (bit of a PITA to look) as a DIY before getting a sparky in at cost.
R-V-M
I took the radio out and all looked fine it will work ok for 15 / 20 mins then it will play up ad none of the buttons will work on it but the next day its the same
Speculating further, if it's after a set period of time, that could be a problem inside the unit since in that time it will get hot (if you've ever ejected a CD after a long drive and felt how hot it is..) so it might indicate a fault with a component?
Again, apart from a sparky, could you switch units with a Fiat owning colleague to see if the same error persists? Perhaps you could try running the radio in the garage at home, out of its housing, car static and see what happens in the permitted 20 minutes run-time before it cuts off..
R-V-M
Hello and happy new year
In the next few weeks i'm taking mine out and replacing it with a double din unit.
mine is a mp3 one and it will come with a lovely box of tricks that you can plug in a hard drive or usb stick or simply use 3.5 mm jack for other music players phone ect.......and all controlled by the head unit.
i'm open to offers but it will go on the bay of e.
LUIGI
LUIGI
any price on it
