the fuse box by the battery contains only a small amount of fuses and these act as the general fuses for the whole car. The fuse you have blown will be found behind the dashboard to the right of the steering wheel. If you remove the panel by taking out the screws you should find many fuses. the fuse you have blown should either be a 10 amp red or 15 amp blue blade fuse found in the top rows.
