stripey stilo
rite just found out this is a very enoying thing to do but is posible.
the main consern is the air bags in the side of ur seats well the drivers side is reasonably easy to do
1) you will need a sub frame to which i have found a company that make 1 for the stilo. on the sub frame there is a resister that u connect to the air bag conector under the seat and then you just attatch ur seat to the sub frame. done
2) pasenger side is the same. but you have a preasure sensore under the fabric were you would sit. all this does is to tell ecu that there is some 1 in the seat and arms the air bag ready for deployment in case of an accident.
in other words if theres no 1 in the seat the airbag wont go off.
so wat you have to do is pull the preasure sensore out off the chair and have to leave it wired up under your bucket seat after fitting
this is the only way to do it so you do not get warnings on your dash.
to pnl i was warned off trying to do this with bucket seats with universal brackets attatched although is probably posible
