Hi just got myself i good mk1 1999 black punto. FIAT PUNTO 1999 1.2 8V Engine
shes all good but i had a good look at the engine as i have good engine knowledge. The timing belt covers have been removed and if i was honest i wud say the belt was fairly new. my only concern is that it seems to shake and wobble near the water pump as if its not tight enough,
i thought that the tensioner was one in which you place a pin in the correct hole to make sure that the tensioner cant be wrong. Can you adjust this without removing all the belt or does it even need adjusting?
Any info and guidence would be good.
