i just got a punto for my daughter, and the power steering is not working,
so i've looked at the threads on here, this is how i think it goes
its an electric power steering,
check the battery volts with engine off need at least 12.5 volts.
check battery voltage at fuse box by steering wheel(i took the plastic cover off the bottom of the steer assembly) get voltage with ignition off and on, volts need to be 12.3.
check the connections to the power steering ecu 9 with plastic cover off in above easy to do)
should be a way to check voltages here but i've not thought about which ones to check, (anyone done this ?)
if the above appear ok, then u need to take car to someone who can get u the codes.
