Hello!
I immediately want to apologize for my English, since I do not know it, I use a translator.
I have a Fiat Punto mk2b 1.2 8v with this problem.
It starts well when cold, after about 20 seconds there are gaps, the tachometer needle oscillates a little.
After warming up and switching to an idle speed of 750 rpm, the engine vibrates with a small amplitude, but a fairly high frequency, as if it does not pulsate.
If you start it hot, the revolutions rise to 2000-2200 rpm and immediately fall to 750 rpm.
Replaced spark plugs and spark plug wires.
The resistance of the primary winding of the ignition coils is 0.5 Ohm, and the secondary is 6.6 kOhm.
There is a difference in the time of energy accumulation in the coils, the first is 3250 ms, and the second is 2670 mm.
When driving, sometimes there is a misfire after 2500-3000 revolutions.
Changed coils, nothing changed.
There are no errors in the ECU.
Please tell me what could be the problem?
I suspect the coil driver.
Screenshot_2023-02-27-19-04-41-962_com.AlfaOBD.AlfaOBD.jpg592.3 KB · Views: 127
Screenshot_2023-02-27-19-04-31-895_com.AlfaOBD.AlfaOBD.jpg580.9 KB · Views: 57
Screenshot_2023-02-27-19-04-25-152_com.AlfaOBD.AlfaOBD.jpg565.2 KB · Views: 55
Screenshot_2023-02-27-22-07-49-144_org.prowl.torque.jpg580.5 KB · Views: 51
Screenshot_2023-02-27-22-07-41-781_org.prowl.torque.jpg552.8 KB · Views: 56
