Hi, im new to this forum but ill get straight into it as ive been trying to find a solution to my problem for a while now.
So, my car is a punto 1.2 16v sporting as mentioned in the title. A month ago on the way home from work it suddenly lost power whilst i was accelerating and seemed like it was going to stall and suddenly kicked back in as normal. It proceeded to do this every couple of minutes on the journey thereafter.
Since then it has been doing it intermittently and more noticeably when i'm low on fuel (1/4 tank or less and even more recently is doing it even with 1/3 of a tank) which leads to the conclusion of a fuelling problem. However when it does lose power i can disengage the clutch immediately and rev the engine to redline without a hiccup. Furthermore, the car does not accelerate properly! Regardless of the amount of fuel in the tank, it is lacking responsiveness especially at the lower end. The exhaust has been excessively blowing out smoke ever since i bought it 4 months ago (even with a warm engine) however it does seem to have got better since then but still does it more than it should now. The car never fails to start nor does it show up any warning lights on the dash and no codes relating to the problem. I also did a full service on the car shortly after buying it.
Sorry for the long post, thanks all
