Hi all,
I'm new to this forum but have been lurking a while. Hello.
I wish to benefit from the expertise of the problem solvers within this forum by presenting an electrical issue I have with my Punto. The issue is progressive in the sense this was once a well-functioning car.
Car: Punto Mk2 8v ELX 2002 (left hand drive)
* Main Problem
Strange behaviour of headlights, and headlights with fog lights. Started over 6 (but less than 12) months ago. Intermittent over maybe 4-6 weeks, now consistent.
1. When driving/engine running with no lights or position lights there is a buzzing noise, alternating between on and off at about 4Hz, coming from the passenger fuse box. Audibly located to one switch/relay relating to the headlights. With position lights they also flicker.
2. Driving with dipped or main beam (not position) there is no buzzing nor flickering.
2. a) Additionally, the fog light operates from the dashboard switch only with main beam, rather than from both dipped and main.
In all these cases indicators, reverse and stop/brake lights all behave as expected.
Practically I am managing with option 2 (dipped). For at least the last 6 months... But it needs attention. Certainly these signs are enough to fail an MOT.
* Call for diagnosis/solutions
I am open to thoughts and comments at this stage. I am interested in a diagnosis but more interested in a permanent solution and getting it through its MOT...
If you want to know more about the fog light and other perhaps related details, then read on.
* Additional Fog Light Information
4. Engine running, operating full beam (away, not flash/towards), then returning to dipped toggles the fog light status.
I can get the fog light on with dipped beam by combining 4 and 2 a), that is from
(Engine running, dipped beam) operating main beam then returning to dipped switches the fog light on. Operating main beam then returning to dipped switches it off.
* Other Related Information
5. This is a personally imported left hand drive. Making it UK road legal involved swapping the rear light clusters for UK spec and rewiring the fog and reverse. This was carried out in 2005.
6. A towbar has been attached(!) and a socket wired in. This work was carried out in 2008.
7. The LH rear light cluster became damaged which allowed slow water ingress into the luggage compartment and saturated the earth point and the wiring exposed by the wiring in the socket. The light cluster damage occurred around early 2010. The light cluster has been replaced early 2011.
8. A mysterious battery draining problem was attributed to sticky passenger lock triggering the central locking continuously. Practically a security issue. 'Solved' only by disabling the central locking by removing the circuit fuse from the passenger fuse box. This occurred mid to late-2010, around the same time as the strange headlight problem was in its intermittent phase.
* Main Problem
