edwin884 Member Joined Dec 26, 2011 Messages 211 Points 50 Jul 25, 2014 #1 Well, it does start... sometimes... But sometimes no buzzing from the fuel pump, and it wont start... relay? Ignition? Pump is ok! Must be the wiring... It's a 1.1 55, 1997... Last edited: Jul 25, 2014
F flisko ` Parked in the garage Written 5 guides Joined Jan 20, 2013 Messages 6,151 Points 1,228 Jul 25, 2014 #2 everytime when you turn key you should hear fuel pump noise, also what do you mean doesnt start, is it cranking?
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,561 Location Liverpool Jul 25, 2014 #3 We do need more information. Fuel pump should run until the requested pressure is reached, then cut if the engine doesn't start. If cranking, check for spark and fuel dribbling onto the throttle body while cranking.
oldhammer Busy rebuilding pand'a Parked in the garage Joined Oct 10, 2012 Messages 5,108 Points 1,075 Location manchester'ish' Jul 25, 2014 #4 Check inertia cut off switch-if fitted with one.
