Hi not drove my punto for around three weeks started it up today to find that there was no pressure on the clutch have been starting it up every 3/4 days to keep the battery going but not driven any ideas? NEED HELP URGENT
Sounds like the clutch slave cylinder has probably had it. I think its fairly easy to replace though have never tried it myself. They cost around £30 - £40 from a good motor factors
have you lost fluid from Brake/clutch reservior ? have someone depress clutch pedal and look at slave cylider for movement or loss of fluid before replacing
From memory the slave sits on top of the gearbox. The "master" is on the bulkhead, down by where the clutch pedal is.. if you follow the fluid line, you'll eventually find the slave.
£90 is pretty reasnable to fit it. £55/60 is labour.
