Technical Punto JTD/ELX Non start
2000 Mk 2 JTD/ELX, No problems for 3 years( except NOISE !) Good enough car.
Problem:- starts first time when cold or cool. When it has reached working temp, switch off , starts ok. 5 -10 mins later will not start, turns ok but no start. Will start OK in 30 mins.
put it into main dealer who told me I req' new set of heater plugs (£265 fitted) No other faults show up on test.(Then charged me £75 !! )
Surely if it was heater plugs there would be a problem at initial start?
Any ideas, wife is well anoyed with it!
Great Site,keep it up. :bang:
hmm i wish i new but im sure i have read several posts on this forum with simalar problems. car starts fine drive stop for fuel car dont start after. have to wait 30 mins to cool down then it will start. things like that. try seaching through the old psosts
this post is about a fiat td engine that after warm wont start recomended the rpm sensor chaneg fixed one guys
https://www.fiatforum.com/showthread.php?t=39486&highlight=start+warm
this post is about same problem fiat td engine starts cold problems when hot was possibly cured with rpm sensor.
https://www.fiatforum.com/showthread.php?t=38494&highlight=start+warm
Thefishdude - THANKS !
I will order RPM sensor and come back to you. Deffinately sound right.
I had disconected temp sender, thinking TEMP , now I have engine mang't light perm't on. Any tips to put out , or back to dealer after I change RPM sensor?
THANKS again !
Johnnyp :bang:
Re engine mang't light:-
It wouldn't go out during stationary running or when batt' disconected all night. Took it for a run on motorway, up to working temp and light went out shortly after, good eh !
Still waiting for RPM sensor
Good Luck
JOB DONE!!!!
Fitted new RPM/ TDC sensor , no more problems.
Fault eventualy only allowed car to run till half warm on gauge, 15 - 20 mins max. Cost £21:21p, Two different types, req chassis No.
Sensor tucked in below starter motor, easy enough job.
THANKS AGAIN !!
jiohnnyp
Hi
Anybody guide me towards a manual / cd for Punto MK2 JTD. Would like to undestand more detail on injection system?
Great Site,
jiohnnyp
