Great diagrams,makes things alot clearer thanks,
Speed 4 goes from the switch straight to the motor and the other 3 speeds go through the resistor aswell.
Hence why u have a classic resistor pack failure
Speed 4 is bypassing the pack
Ziggy
Yeah and now all i need to figure out is why when replaced it still blows the diode.
Either the blower motor or speed switch is faulty as they the only things left on that connection which keeps taking out the resistor.
All the wiring & connector blocks from the resistor to the motor look fine etc.
Whats the best method to test the motor is working correctly? and the speed switch?
Thanks all.
When i bought the new resistor which ive give the link to in a previous post here, i did wonder if it was the correct one with it blowing the diode so quick?
Are there different resistors for each punto make?maybe it just needs the correct resistor fitted and it will be sorted lol.If i get another and it blows again we then know its not the resistor but then its a waste of cash finding that out.
Im not great with multimeters but with guidance i can manage it as im not sure best way to do a resistance test without chopping wires to get in the circuit.
Other than that i will take out the motor and have a look at the condition and see what it runs like powered up.
Thanks again.
