Technical Punto 1.4 fire emotion 2009 , no cranc , immobilizer symbol
Badal
Nagpur
Hello All,
Am new here, I bought used Grande punto 2009 petrol model. I get intermittent immobilizer symbol (padlock) and for last three days am even unable start my car.. tere is no crank.. pls any help... My cars central locking also somtimes automatically startr working and sometimes automatically goes off.... Airbag failure and boot open message is always there... Any help pls
I would like to share something more... These all problem started when I had an accedent and mechanic replaced my gear box with a used one...
Possibly the accident caused the other car problems you've mentioned. Its difficult to say.
Thanks Anthony for replying,... I showed many mechanics but evryone is telling different storys.. some say key faul, some says body computer fauly some says immobilizer faulty... What to do
Would like to add more... After changing gearbox car was good to drive... I was using it even after the immo symbol intermittent... It goes off after several times I turn key off and on and car starts and run smoothly... But for last 3 days I can't start the car.. there is no cranck
Hello All,
The symptoms you describe say the key is faulty. They are known to fail with age. If that doesn't fix the problem you'd try something else but I'm 99% sure you need a new key.
I don't think the key is culprit... Because mechanic did something to like strocking the starter motor and it started.... I drove 2 days smoothly ( approx 360km) and today problem of no cranck started again
When the padlock is off the car starts, and when the padlock is on the car won't start. Is this the case? If so you need a new key.
Padlock is intermittent... It comes sometimes and sometimes it doesn't ther
To progress you need to answer the question...When the padlock is off the car starts, and when the padlock is on the car won't start. Is this the case?
Yess for 3 days before... Now it don't start at all
But car should crank even if there is padlock symbol.... Isentit?
