I have an intermittent starting problem on my 1.2 8v.
When the key is turned to start the engine, it will start and then cut straight out again. Then when I try again, it will turn over, but sounds as if there is no fuel in the chambers, or no compression. I have to give it some gas to get it to start then hold the revs on for a couple of seconds. If I give it the gas and take my foot straight off, it will die again. Sometimes it will start first turn of the key. Other than that, it runs sweet as a nut.
Also, since having the clutch changed, 5th gear is very close to third and reverse can be selected without lifting the collar up.
Any help would be appreciated. Thank you.
