Technical Proxi alignment
tonyspunto
Ive just swapped the instrument cluster in my sons 2001 1.2 8v mk2 punto, we now have both airbag lights on and the engine management light on along with what i believe is a gearbox warning light ( it is possible the new cluster is from an auto where as ours is a manual) and of course the digital display is flashing. I know i need a proxi alignment, my question is does anyone know of someone in kent ( im in the tn13 area) who could do this for a reasonable price.
Thanks in advance.
If you plan to keep the punto - get MES (Multi ecu scan) Full edition and do it yourself :)
You will need a suitable cable tho
It'll probably work out cheaper then going to an auto-sparky todo it
The software will pay itself up after a few code reads, or beer tokens for other owners of fiat cars as well :)
Ziggy
homeward
Brain stopped play
On the hard shoulder...
Ziggy 122 -- will a cluster from a Speedgear work in a manual? The display is wider (to accommodate the P, D, R, etc., in the middle...). :confused:
It certainly won't work, the other way around...! ;)
You know what - i wouldnt know.....
I cant see why it wouldnt tho - as surly it just wont display DPR etc
Its like diesels going into a petrols, i think it should work, but i am not 100% sure
Ziggy
OP
OP
T
tonyspunto
Ill take a pic of the new warning light, ( ive had a look at the original cluster and this light isnt there)
s and b
i would be concerned trying to get an auto cluster to work as you would need appropiate comfort bsi unit
OP
OP
T
tonyspunto
Quick update, have got multiecuscan and all relevant cables, i have proxi aligned successfully and corrected the mileage, no air bag warnings, no engine warnings, but i still have the auto gearbox warning, ecuscan says gearbox failure, ive cleared the fault but the damn light wont go out. Every else works correctly, anyone know how i can fix the warning light ? , short of removing the led.
oldhammer
Busy rebuilding pand'a
manchester'ish'
iirc its normaly iffy wiring on back lights that cause the autobox warning light
to flag up.
AndyRKett
Well-known member
Norfolk UK
as previously stated there is incompatibility between autos and non autos basically when you proxi-aligned the new dash you taught all the other modules there is an Auto dash so must be an automatic, but now obviously it can't find the auto-gearbox so is throwing a hissy fit, you need the dash from a manual car and to re-proxi-align
IF the fault is JUST the light - I'd be much inclined to remove the light for the gearbox
It wont fail an MOT for it - because its a manual car
it wont come on with a manual gearbox as there no ECU for that
If the dash works 100% otherwise, remove the light, but becareful doing so, its a soldering job
Ziggy
s and b
Ziggy
its in the lcd display bit though shurely shirley
