problems with tipo
problems with tipo
drago_tuner
tommorow when i went to mechanic i found something on my car..i saw that front wheels are expended becase whole caroserie is expended..i dont know what to do??i shold put something under the car to make it stronger but dont know what?did anybody have that problems??:eek:
custard
Status: DEFCON Grumpy
Edinburgh
okay 1st you meant yesterday not tomorrow but i know english is an awkward language to get around :)
as to your post im not to sure what you mean?do you mean the tyres are worn out?
OP
OP
drago_tuner
drago_tuner
i meant tommorow..tyres are very little worn out..but dont know how to explain..(those 2 things that goes from gearbox to wheels )are on the end so they sometimes just fall off from wheels..and that is because caroserie is expended..i dont know if there is to buy front lower strut brace or if someone has done it alone..
sumplug
sunny Spain
carroserie means coachwork. you mean the driveshafts fall off. the strut is moving out and splaying out at the bottom. you must have worn suspension and springs. worn springs will force the wheels out.:)
OP
OP
drago_tuner
drago_tuner
sorry sumplug..i dont understand you..yes driveshifts fall of..i checked suspensions and springs and everithing seems ok..they are also new..many mechanics told me problem is in coachwork(it expended because car was crashed...)so i want to know if there are strut braces but under the coachwork..
sumplug
sunny Spain
well, you could make one. two bars bolted to eachi nner wing with a male and female thread for tightening.:)
OP
OP
drago_tuner
drago_tuner
i know..i will make it..always problems with fiat:eek:
NW London
I heard that if you lower your car too mauch this can also cause problems unless you change the whole suspension set up. 40mm was the practical maximum on a Tipo if I remember. Anything more and you should expect exessive tyre, ball joint wear etc.
