Dear Forum Members,
I've been a member and reader for a year or so now, but this is my first post. I'm hoping that some knowledgeable members can offer some advice.
I own a 66 plate Panda Easy 1.2 (my first ever car) which I bought at just under one year old with low mileage. I use it for both short local trips and generally a longer motorway jaunt every month or so - although these longer trips have been less frequent since lockdown. The current mileage is 28K.
The car has been great up to now - no problems at all and drove very nicely. I've looked after it and had it serviced yearly. About four weeks ago I had the car serviced (oil change, new sparkplugs etc.) and also had the cambelt changed as it's now five years old. I went to a local Fiat independent garage which I had used the year previously with no issues and which appeared to have a very good reputation according to online reviews at least.
I picked the car up and drove it about 5 miles home with no problems. The next day after about 20 minutes of driving the car began to bang and shake (I'm assuming this was a misfire) and then lost just about all power - the engine did not rev at all with accelerator input. Is this the ECU putting the car into limp mode? It didn't cut out completely as I could just about crawl along at 2 or 3 mph to get off the main road and park up. I turned the engine off. After a few minute I turned the key again and the car appeared to start fine and did respond to the throttle. I managed to get home which thankfully was only a few minutes away.
The next day I tested the car, but just in the quiet neighbouring streets. It started fine and revved up ok while stationary. After about 10 minutes of driving the engine power cut out again - this time with the engine warning light. I managed to restart and drive it around the corner to my house.
I phone the garage the next day and they came and towed it back. Diagnostics showed that the error codes read as misfires in cylinder 1 and 4. They said that the belt/timing seemed to be ok and that they could not see any other obvious problems. They suggested it's likely to be the coil so I had that changed at a cost of £200.
I went back to collect the car and the misfire/power loss happened again about 100m from the garage. Parked up, restarted and took it back straightway. Misfires in cylinder 1 and 4 errors listed again. They had it for a couple of weeks in the end, but said that they were unable to recreate the faults despite one of the mechanics driving it home in the evenings. Again they said that the cambelt was fitted correctly - I'm assuming that they stripped it down again to check this? - and that the car seemed to be running fine. They said it might have been an ECU issue - but I'm very reluctant to let them start swapping parts without any guarantee it's going to fix the problem. .
In the end I went back and collected it. I've now driven about 10 times over the last couple of weeks. The obvious misfire/loss of power has not returned, however to me it feels that the car is still not right. It's rougher and more uneven at idle and there is a slight but very noticeable constant hesitancy/shake in normal driving. My concern is that the power loss issue will return without warning and I'm reluctant to take it on the long motorway journeys planned for Christmas. I'm also worried that any mis-timing might damage the engine.
I've been reading the cambelt relating posts to try and get some ideas. I'm assuming that the garage would have known if a phonic wheel relearn was required? Is that standard practice when a belt is changed on a panda? If the timing (as they have said) is correct is there anything obvious that could have been damaged or not put back properly which could cause these issues.
I'm thinking of taking it to another garage (possibly a Fiat dealer) for second opinion - it would be great if anyone could offer some pointers before I talk them.
Thanks in advance for any replies.
