Technical Problem again: jerking clutch
Hi
when depressing clutch pedal the travel is like jerky, mostly when warm.
clutch kit changed months ago(it was winter and it was fine), i put enough grease onto that gearbox shaft where is clutch bearing moving, also removed and put grease onto pedal hub, clutch cable is 2years old, also greased
its not serious failure, its just not that smooth-any ideas?? thanks
edit: otherwise its working great, shifting smoothly
will check it on weekdays-disconnect cable at pedal and see whats wrong
earth lead was cleaned when g-box mounting back
i put loadz of grease at pedal shaft, cable is 2 years old, i greased it but couldnt it be jammed clutch bearing at shaft..?? (iam worried of this, wont remove g-box again....)
