Technical Preventive maintenance?
nigelvan
Belgium
Hi guys,
Our 2007 3.0 Jumper has undergone some repairs and checks thanks to advice on this forum. We are almost ready with the conversion to a camper and inspection (Belgian MOT) is coming up.
So far I've replaced the throttle body, serviced the van, replaced the brake discs and brake fluid, replaced the headlight, fixed the mass between engine and chassis and inspected the wire loom for damage. I will be replacing the rubber supports for the exhaust when they arrive.
Since so many small things were wrong I wanted to ask if there are other parts I should check/replace before going on long trips. I've ordered another headlight (one new, and one decent one doesn't look too good) and I was planning on taking out the EGR and clean it since it seems easy to reach with the headlight removed.
Should I take a look at other things or weak spots? Thinking about turbo, other fluids like servo fluid, transmission fluid...
The car has 116000 km (72000 miles) on it.
