Power Steering Giving Out?
TMS007
Napoli
Howdy everyone!
I'm an American living in Italy and am about to sell my 2007 Fiat Panda. It has been sitting for a few months and completely dead. I replaced the battery and it runs great
The problem is that now the power steering randomly gives out and the red light comes on. But it fixes after awhile. Also the wheel makes a clicking sound when turning? But it might be the light clicking on?
koalar
Well-known member
Cheshire
Almost certainly due to being sitting for a few months
If you jack the front of the car up does the steering feel smooth from lock to lock
“clicking sound when turning”
Inside the car or outside?
Felt in the steering wheel?
OP
OP
TMS007
TMS007
Napoli
I don't have a jack to try it out unfortunately. But the power steering gives out periodically, I'm not sure if it's one way or the other.
The clicking is coming from Inside the car. It sounds like it's coming from the steering wheel area.
OP
OP
TMS007
TMS007
Napoli
Sorry about the delay, service out here sucks. Had to upload to imgur because the file was too big. Looks like it's primarily happening on turns?
Https:// imgur.com/a/9KbluBW
koalar
Well-known member
Cheshire
I think I would start by parking on some gravel or grass
Raise the revs to around 3K and rapidly move the steering wheel from lock to lock
It’s reasonably common for the steering to get in a knot after changing a battery. Sometimes flicking city mode on and off a few times also sorts it out
The earth for the steering motor is the black cable separately bolted to the negative clamp
OP
OP
TMS007
TMS007
Napoli
Thanks for the advice, I'll text these out after work and double check the battery connections. I'll be sure do update this evening.
DaveMcT
Well-known member
Alternator stators corrode internally and will eventually reduce performance before they seize the rotor or just stop charging. Poor charging might not light the warning lamp but it will leave the battery too low to do its job.
Check the the alternator casing for cracks and internal swelling. If it is cracked you'll need a new replacement as it's beyond repair.
The Panda Nut
Nutty about Pandas Infected by Panda virus and OPD
East
The internal noise could just be the self cancelling ring at the top of the steering column. Our Uno used to do this a sort of ticking noise as you turned the wheel. A squirt of silicon lube would quieten it down for a few months but its a faff getting at it to find out.
