hi guys, had my cinq on the road for few months now, 899cc sx :slayer:. but it has a bit of a power loss issue. will drive fine and runs spot on but every so often it holds back as if it has run out of petrol or the battery has been dis-connected and the injector light comes on and off every so often :bang:.
but it only happens for a second then it behaves fine. the problem is i cant trace it. i have put a new fuel filter on the car 2 months ago. then today i decided to have a crack at it so i changed the spi carb, coil packs, plugs/leads from my other cinq (which i know was all good) the problem now seems a bit less frequant and the injector light has not come on since. it pulls much better but still holds back every so often.
im running out of ideas , i figure it may be my crank sensor so gonna try that but what else could it be? any ideas welcome as im on the verge of trying to persuade it with a sledge hammer and some un-pleasant words
