Yeah I'm pretty sure the 1.2 (it's really a 1.25
) has a larger throttle body than the 1.1, but not by much.
So you dumped a 1.2 in the Cinq? Nice! I'm trying to imagine the new dimensions. For improving the power side of things? Have you already fitted K&N element to the air intake side of things? That's essential, along with some quality plugs (I forget the codes, it's all round here somewhere:I)
Aside from that, try a Peco DTM system, you could get it superchipped, you could get higher spec camshafts (Fiat fast roaders are £150, Abarths are something nearer £500 last time I checked) and a lighter flywheel would sure help it to rev more freely (though there are drawbacks for all these, mostly at low speed manoeuvers). I guess it's where to draw the line with the 1.2. In the Cinq it's probably worth maxxing out the 1.2, if it were the Punto I wouldn't bother.
You could even uprate the head gasket.
In my incompetence I've forgotten if the 1.2 is an 8 or 16 valve? I never had a 1.2, but if it is 8v try and make it breathe as easily as possible. Anything to increase and regualte the air flow is good, and it's often not that expensive. Don't forget the exhaust either. Um (racking brains) maybe you could insulate the exhaust manifolds with some sort of material similar to asbestos or pipe lugging, but make sure it's fire-proof. this will help keep exhaust temperature high which should make intake temperature less. It's worth spending teh money on high performance leads too.
I'm curious, what bits remain from the Cinq in the transmission or did you do a complete Punto unit swap?
Spirito di Punto
