power cable for bravo HGT
Bravo_HGT
United Kingdom.
Had a quick look today and cant see any where to run a power cable, is there a gromit? there is bugger all space under the bonnet to look.
You can only fly as high as the dreams you dare to live
having the exact same problem m8. dont do what i done. found a rubber pipe going into dash, cut it and ran pipe through.,, turned out to be sunroof draingage pipe. major water leakeage and a bar steward to repair lol
im still looking for somewhere to run it through,..
Where does the battery wiring run into the car? Run it through there?
Matt
______________________________________________________
http://www.zen8627.zen.co.uk/Matt/
54 bhp of pure Italian muscle
Its not as simple as it you think it would be,
The power cable along with the main loom run through the bulkhead on the passenger side just under the windscreen into the upper section of the dash. directly by the main loom is a sunroof draingage pipe.
inside the car the loom comes into the car and the drainage pipe is about 10 - 20 cm away from the loom. which leads me to think the bulkhead is made up of 2 walls. the loom itsself is in some specialy manufactured rubber sleave which is completly sealed. no way of running a power cable down there.
ive spoken to wimmy about it to see how he did his, and he has run a cable through a hole drilled near the floor of the passenger footwell. i think this is the best and only place which a cable can be routed. the only problem im finding is that to access this in the engine bay is hard work. requires either romval of battry and tray or access from under the car. ive yet to figure how to easily get the sound deading off aswell..
id imagine bravo HGT will have more problems than me. that 5 cylinder lump gona be making it even more tighter for space..
damm, looks like im gona have to get up early and make it a mission one day this week, cheers for the info guys and girls.
