after failing to install the rings to the speedometer,it was the roofs turn. i had a leaking problem which was a result of extensive heat in the summer combined with the weight of the roof ''unglued'' the roofs subframe. now i am thinking to replace the heavy crystal with plexiglass which is so light but....only problem is the scratches it gets. but there is a small solution of that to.clear adheshive plastic cover.what do you think?
