hey i just purchased a new headunit, its one of those in dash dvd players with the screen etc,
anyways i got it and bought this cable harness so that i could connect all the wires properly for the headunit, i finally did after some time and everything was working fine, headunit worked perfectly.
After i finished using the car i turned of the headunit but a small red sort of stanby light stayed on, and i thought it wd turn off after i switched off the ignition or after some time, but it didnt.
i turned of the ignition and waited around 20 mins but the light remained on (seems to be like a stanby light)
i thought to myself, this must be the way the headunit was desinged so i contacted the manufacture of the headunit and asked them and they told me their was nothing wrong with the headunit but that the red small stanby light should be switched off when the ignition is turned off, they told me to check the cables and i did so many times ad everythiung is properly connected i guess
PLEASEEEEE SOMEONE HELPPPP
i got a fiat punto 2004 5 DR
my headunit is conected normnally, both red and yellow wires conected together and ground (black)conected to ground etc
PLEASE can someone help
kind regards
NIGEL
kind regards
NIGEL
