Danielejones
- Joined
- Aug 10, 2012
- Messages
- 9
- Points
- 2
Hi to all what a great forum, I am having a problem with my punto it's an 1.2 8v on a Y plate - 2001
The cars engine management light comes on and flashes there is a misfire I know that, it goes from 4 to running on 3 and sometimes 2, the spark plugs are black and when I clean them, they turn black pretty quickly. All spark plugs seem to spark, iv tried the coil pack test that I read on here, the leads are all ok, there is a white substance under the oil cap, and under the rocker cover, but the dipstick is clean and has a beautiful fresh oil look to it as it was changed only 1000 miles ago, it's not using any water and it doesn't over heat, the fan kicks in as normal, takes a little longer then I think it should to reach temp, is there anything I can try or change or maybe someone has any advice if they have experienced the same problem? When you drive it the sound is like a bum, bum, bum, bum out the exhaust then will all of a sudden kick up to 4 and sound normal then go back to struggling with power and so on,
Could it be the injectors?
Head gasket? Maybe gone between 2 and 3? But why isn't it using water or over heating?
I'm just lost as to think what it could be? Don't want to strip to head gasket to find it ain't that. Want to try smaller things first.
Thank you
Thank you
