Technical Plastic wheel trims
hi, i've aquired some standard trims for my sx.
how do these affix to the wheel? as it is the bolts go through the hole and won't hold them on
thanks
James
AppleSei
RIP L181 VBB
West Yorks
The bolts are there for show IIRC, its the small circular rim at the back that is the fixing element. If the bolts arent for show then there will only be one way in which they go on, like all wheel trims just kick them on
tie wrap them for extra security and fitting
OP
OP
J
i've had another look and three of the holes are small enough to be held on with the bolts.
there isn't any other ring to secure them
however when securing with the three bolts the edge flare out so as not in contact with the wheel
OP
OP
J
hi, they are like this on the front
three are like this on thwe rear
one has these raised sections which makes isn't helping
and they are going on these..
AppleSei
RIP L181 VBB
West Yorks
your cinq wheels are 13''
those look like uno or tipo trims to me, they may be possibly 14'' if that is case they wont fit. You will need to take your wheel nuts off, put on the trims then refit your wheel nuts
the one with the big mark looks water damaged, would have possibly not bought these
OP
OP
J
i've just measured thwem and they are 13.5 ". :rolleyes:
they look fine from the front. i don't think the mark has damaged them
i was pm'd by a member of this board in repsonse to a wanted ad for some cinq trims. paid for them and got these through the post :(
