Hi folks
Just done a cambelt on a 500 1.2, early Euro 6. I used the proper tools, slackened the cam pulley etc. It started up fine, ran very sweetly at idle up to temperature (I did the water pump too so was bleeding out the air for some time).
I've done a few now and this is the first time an engine management error has been reported during the run up afterwards (at idle). OK, methinks phonic wheel relearn, no problem...
However, it doesn't seem to work. The initial reset using Multiecuscan appears to work OK. (I do this with key on and engine not running - presume that is correct). I then turn off, leave it for sixty seconds, start up and do the 3 revs (fairly immediately) but it doesn't seem to be eliminating the error.
First time I tried it allowed me to rev to 6000 rpm but on subsequent attempts it wouldn't let me rev past 5000 (the EML changed from steady to flashing at this point).
Any thoughts? Does one need to let the car idle for a while? I have been doing the procedure with the car hot and doing the revs immediately - do I need to do it from cold, allow it to warm up and do the 3 revs then?
In short, is it fairly foolproof or is there a very precise procedure or sequence, some of which I'm not doing right?!
One thing I noticed in MES for the Euro 6 1.2/1.4 is that there are loads of similar but different procedures - phonic wheel relearn, replacement of timing sensor or cam, replacement of RPM sensor or distribution belt.... I've tried the first two but no difference.
I also have a P0016-76 (cam shaft assembly position) error but I'm assuming that's just because the new timing is different from previously.
Tomorrow I will strip down the engine again (sigh) to check the timing hasn't slipped but thought I would check the collective wisdom before I do....
Thanks!
Nick
Thanks!
Nick
