Technical Panda seat swap question
NigelO
I’ve seen several threads about fitting 500 seats into a Panda (with a bit of fettling on one mount?)
My Panda seats are a bit knackered, so I’m thinking of doing the swap. However, from what I can see, there was a change to the 500 mounts at some point, so I’m worried that some 500 seats may not fit at all.
I have my eye on two types - can anyone confirm if these will / won’t fit?
Straight up I don't know for sure
The electrical connect on the 500 seats, heater and airbags are different and changed around 2012
As far as I know the physical frames haven't altered, so will require modification
Don't forget you need all the catches and latches if you are swapping the rears also
Thanks - I’m collecting the blue-stripe seats tomorrow. I’m fairly handy with a bit of DIY, so I shouldn’t have too much hassle swapping rails or fabricating a bracket. I’ve made sure that I’m also getting all the rear seat brackets and the cross-bar (my 4x4 doesn’t have a split back seat)
Hopefully these will make longer trips a bit more tolerable - the current seats get quite uncomfortable after a couple of hours
Well, that wasn’t very hard…
Three of the four mounting points on the 500 seats are identical to the Panda. One is completely the wrong orientation. It’s simply a case of drilling out the rivets and swapping the Panda bracket onto the 500 seat rail.
Both front seats done in three hours
Panda bracket - holes part-drilled
500 bracket-
The end rivet on the 500 bracket is impossible to reach with a drill bit, so I jacket it off-
Then drilled out the rivets-
Brackets removed-
Panda bracket bolted to the 500 rail with 2x M8 Allen bolts and Nyloc nuts-
And in the car…
The difference is night and day - much more comfortable and loads more support. They look loads better
Rears are in too - bit of a faff, as the seat base is quite different to the panda base, so there was a sizeable gap between the base and the seat back.
However, I got inventive with some box-section aluminium and raised the back of the seat base, so the gap isn’t really noticeable now.
Just spotted an unfortunate auto-correct typo in my post from yesterday… would a kind Mod please replace ‘jacket’ with ‘hacked’?
Bloody iPad…
I'm considering changing the front seats on my Panda (2010 1.1 Active) with either something from a 500 or Panda 319. Did anyone work out if they do become completely incompatible at some point in production? And are the above seats from an Abarth?
They always fit
They always need modification
Both arbarth and none arbarth have been fitted
Later seats have a different airbag connector, which normally of no concern in most pandas
