eldwickjke
- Joined
- Mar 19, 2015
- Messages
- 2
- Points
- 1
My wife's Panda Pop 2009 has an intermittent fault which starts with the engine management light coming on, and throws her into a panic. The light goes out, but then the car will cut out. It restarts readily enough afterwards, but we find that the clock has reset! This has happened several times now, the last time today, and actually at the garage so the man was able to witness it himself. It looks to be some sort of electrical fault, but because there has obviously been a reset in the engine electrics, there is an absence of any fault codes, and my man seems stumped and is sending the car to a 'specialist electrician'. It all sounds as if it is going to be very expensive. Does anyone have any ideas as to what might be going wrong?
