That's interesting, thank you koalar. I was very impressed with the lack of bodywork rust on my Panda, especially compared with the Mazdas of similar vintage I'm used to (which are killed by rear sill and wheel arch rot).
Is there anywhere else on the body they are particularly prone to rust? I'm familiar with the coolant return pipe, rear axle, springs, brakes and front wheel arch mud trap.
Presumably Dinitrol or similar sprayed inside the access holes for the rear sills would be good to keep it at bay.
The rear sills are normally the first place. If there good everything should be okay.
chassis legs under the bonnet. There's a weld line and drain hole that start to bubble but don't seem to rot away.
not affect my cars but the scuttle would be worth checking. They fill up with rotting leaves if the cars been parked under trees.
there's a mud trap behind the front inner wheel arch. At the front edge
