General panda front track width !!! anyone know !?
Xsisley
Hebden Bridge
as the title says really,
need to know the track width !
haynes old and new says 1254mm
but somewhere on the net said slightly different.
can anyone confirm !
thanks panda people !
ohhh also, if any has the front track width of a cinq sporting that would be very handy too !!!
thanks.
aran.
Hi Aran,
The Haynes bible says Cinquecento front track is 1264 mm, trust this helps?
My Panda/Lancia Y10 based Onyx Firefly has just had major surgery!!! Cinqe
gear box ,gearchange, Punto 75 engine balanced skimmed ,bored to max, webber carb on hand made inlet, cant do with all this injection stuff!!!.
Help I need a suitable taller sport exhaust manifold if you know of a source?
Cheers
Iain
PS the idea is to try hillclimb time trials next year
when i did a 1242 8valve conversion on my 4x4 the i just re welded the exhaust downpipes 20mm longer. was a very easy way of doing it.
hope that helps.
or you could get a spare/scrap downpipe the same..
cut the top plate off it which is about 15mm or 12mm thick
then fit the cut off plate and two gaskets to the manifold-downpipe joint.
aran.
