Well, changing the rear disks on my Cross has turned into a real ball ache. Passenger side changed ok aside from the usual issues of getting to all the bolts but the driver side was a bit of a disaster. Basically, the 2 hex head bolts holding the calliper carrier were seized solid and, eventually after a lot of heat and much pressure, the hex holes rounded off. To cut a long story short, I had to remove the hub nut, take off the hub and even then, with easy access to the 2 offending bolts I had to drill through them and use more heat and a stud extractor to free them. I now just have to put the whole lot back together.
However, I have no idea what pressure the hub nut needs torqued up to or if it needs backed off or not. I do know it was f tight and a lot of effort to remove.
Can anyone advise what the hub nut needs tightened to please?
